Hey guys long story short.
Ford Figo 2012 1.4 Ambiente Petrol.
Duratec motor.
Cracked/warped head in July 2022
Complete engine rebuild new head and gaskets. Mechanic did not replace the pieate part water bottle and cap also did not join the resevor hose nicely.
Got the car back in December, drove it for 2 weeks.
My partner had the car stuck in traffic.
Hose pops off drives the car for anout 7km without water in traffic to a garage.
Hose is reconnected and quick water/coolant replacement.
Drove car home about 30+km
Checking car in the morning, blown gasket again. (Sludgy deposit in oil filler cap and film of oil in resevoir)
Cue Loctite block and head sealant.
Cars been purring for about 35 000km.
25/7/2023 stuck in traffic, white steam coming from water reservoir.
Water bubbling in reservoir and leaking out the cap coolant drained out as the initial leak was green.
Topped up with water and finished errands.
Cap popped off twice due to traffic. Replaced each time. (Car didn't overheat- [no warning light] fan operational, reservoir still bubbling)
There is no coolant in the resevoir due to the leak out.
26/7/2023
Did a short local drive this morning only enough to get the fan on. Didn't notice any bubbling or leaking.
No sludge in filler cap however very light/patchy oil film and oil smell in water resevoir (less than 2 drops)
I want to check the spark plugs for oil to confirm the gasket isn't blown
1) should there be signs of a blown gasket, Can I just use another bottle of loctite?
(It worked before when there was sludge present in filler cap)
2) should I flush the radiator and add new coolant + replace water bottle with genuine ford
3) how do I check if my water pump is faulty?
210355km on the clock
