Router does not sync a the correct speed and will resync constantly. I've had a 2mbps line for over two years without sync issues and it would always sync at 2048kbps, but when I logged a call with Telkom, the technician claimed that I'm too far from the exchange to get 2mbps. I feel there is an underlying issue as there is also quite a bit of noise on the line.
Phone number: 041 452 xxxx
ADSL line speed: 2048kbps
ISP: Afrihost uncapped business
Time: Throughout the day
Traceroute:
Tracing route to telkom.co.za [196.43.22.222]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 10.0.0.2
2 80 ms 66 ms 68 ms 105-236-12-1-esr-lo.mtnbusiness.co.za [105.236.12.1]
3 61 ms 35 ms 65 ms 41.181.201.94
4 107 ms 76 ms 121 ms tb-dca-2.za--qux-c.za.mtnbusiness.net [41.181.198.188]
5 86 ms 93 ms 98 ms unc-cpt-1.mtnns.net [196.44.18.8]
6 188 ms 96 ms 126 ms tb-pr-1.za--tb-cr-2.za-a.mtnns.net [196.44.18.143]
7 59 ms 31 ms 65 ms wblv-ip-se-2-gw.telkom-ipnet.co.za [196.25.165.197]
8 46 ms 36 ms 55 ms 196.43.25.205
9 108 ms 76 ms 49 ms 196.43.39.162
10 132 ms 134 ms 119 ms rrba-ip-bssr-1-ge-2-48.telkom-ipnet.co.za [196.43.23.6]
11 136 ms 139 ms 186 ms nbsc-ip-bssr-1-atm-5-0-0-1.telkom-ipnet.co.za [196.43.23.30]
12 113 ms 102 ms 71 ms nbsc-ip-rcache-1-vif0.telkom-ipnet.co.za [196.43
.22.222]
Trace complete.
Sync speed:
Varies all the time - anywhere between 992kbps and 1920kbps
Attenuation:
52.5db downstream
31.0db upstream
Noise Margin:
2.4db-6.5db downstream
+/-13db upstream
Traceroute:
.22.222]
Trace complete.
Sync speed:
Attenuation:
52.5db downstream
31.0db upstream
Noise Margin:
+/-13db upstream
