Bluefinllama
- May 21, 2011
I am having trouble with my uploading speeds and I'm unsure if it might be my onboard Ethernet that is giving the problems? When I use a wireless adapter the speeds seem to be fine, as soon as I go back to cable it just doesn't want to do anything. Would the most likely problem be the Modem / the Motherboard? I have installed the latest broadcom netlink drivers for my motherboard.
Have any of you perhaps come across a problem like this where the onboard ethernet doesn't want to upload, but is fine when downloading? I've experienced this problem before with the same motherboard and modem, but it seemed to have fixed itself after I formatted, but I used the same drivers / Windows etc. as before.
I am using Avast free antivirus, but I've turned off all the shields and it didn't make a difference, so doubt it could be this. For a while I had a problem where my monitor didn't pick up a signal from the graphics card at times (random times, there was no discernible pattern to the occurence) but it seems fine now (re-seated all the components including the graphics card).
I have an Asrock Z77 Extreme 4 and I'm using a TP-Link TD-W8960N. I did order a ZyXEL Z-P2812HNU-F1 VDSL modem since I am in an area where I can make use of VDSL, so I'll be able to test as soon as the modem arrives.
Any input / ideas would be welcome.
