Help deleting wireless network
Avenue
Johannesburg
Disclaimer: I have no idea what's happening when it comes to networking.
I am using XP sp3.
I was messing around and opened control panel > Network and internet connections > wireless network setup wizard.
I followed the prompts and created a network called 'MyNetwork'.
Once it was completed I couldn't figure out what had changed so I decided to delete that connection. Problem is I cannot find it anywhere. I have no idea where or what it created.
If I run that wizard again it now says
Create a new wireless network,
or
add a new computer or device to the 'MyNetwork' network
So it does exist. But how do I find "MYNetwork" and delete it?
Hi There,
I am surprised that the 2 orange support links failed to find the item something must have gone wrong in the steps you followed.
I am not sure if this will work but what about doing a system restore to before you tried to create the network?
I also dug up this old link on XP and Wireless connectivity. Maybe following it you might get it resolved.
Let us know how you get on
Regards
Tim
