"Help me fix" aka DIY help needed thread
Suggestions on easiest way to fix luggage bag handle? I'm thinking binding/connecting screw?
View attachment 1874084 View attachment 1874085 View attachment 1874086
A rivet or a machine screw and nut.
If you rivet it you must put in a removable spacer that is removed after installing the rivet, that will release some of the tension and if you don't do that the handle will be clamped to hard and won't be able to move in and out of the side covers.
  • Like
Reactions: SHL
