Help setting Qos on router
ViciousClone
Western Cape
Hi guys so i cant seem to find the qos section on the router or how it should be done
Its a mweb fon - tg589vn v3
When someone in the house gets onto facebook ect it drags my 10mbps line down hard
Get a better router. The Mweb fon routers are cheap pieces of crap.
If you flash the router to proper firmware you may have better luck getting qos set.. check this link on how its done.. http://devrandom.za.net/blog/2014/02/16/unlocking-a-tg589vn-v3-vdsl-isp-locked-router/
In that link is also a link to the original firmware documentation which you should go through to make sure you will be happy with the qos options that may become available before flashing.. there is always a very real chance of bricking the router when you flash it.. so be warned..
Already flashed this morning.
Now to sort the QoS
