Hi,
I need some advice. Here is my problem!
In the office we have 2 routers on two separate ADSL lines.
1 x adsl for voip
1 x adsl for web
We have 10 pc's connected to web via wireless & we have 10 voip phones connected via wired cat5 lan.
So voip is totally separate and quality can be managed we keep it on it's own line. Problem is sometimes we need to use soft phones as a backup.
We use X-Pro softphones which can be configured to almost any need. What I need to do is to be able to get just the softphones to be able to connect to the same network as the hard phones so that we can control the quality of them too.
Each pc has a lan port and a usb wireless receiver.
So I was thinking would it be possible to run the pcs with a lan cable for the softphones and wireless for internet?
From what I can see the softphones can be given a dedicated IP but I am not sure how I would still set this all up?
Any ideas?
Thanks for any advice you can give.
1 x adsl for voip
1 x adsl for web
Any ideas?
