How much data does phoning from Hauwei LTE router use?
[email protected]
Hi there guys.
I have got a normal telephone connected to my Hauwei B593 Router on a normal 7gig Smart internet plan at Telkom. I would just like to know how much data will it use when phoning on the data plan. An how do i set up the router settings so I can use the telephone.
Thanx alot
Hi,
Do you need to specify a SIP account on the router? Like a Analog to SIP gateway?!
If it is like that, real world is less that 1gig for a client that does R1500 worth of calls.
Depending on the SIP provider/codc, 30kbps avg.
Hello Ruan,
As G says, it's 30 kbps when in use. That's 225 KB / min or 13.5MB per hour. When not in use, it's much less. So you can't use up you 7gig, not matter how much you talk.
You will need a SIP account. Check out my review on the VOIP forum to see what your options are.
