How to drain wrong fuel from a car
Odwa_M
Strand
So, yesterday I had an unfortunate incident of having diesel put into my petrol car. I would like to to know how to drain the fuel from the car and what damages are likely to have occured. The car is a Hyundai Getz, if that makes any difference.
TIA
TIA
So this did not happen at a petrol station? (I don't think diesel nozzles fit in petrol cars, only the other way around)
Yah, nevermind if you actually tried to start your car. The diesel won't ignite but will now be in all your engines chambers :(
It happened at a petrol station.
Attendant must have held the nozzle above the pipe, I'm sure it would have blocked it otherwise.
Do you even get diesel getz? I had to insist for my corrola in the 2000's as it was extremely uncommon.
Just set it on fire, that should solve the problem of the wrong fuel
They had CRDi Getz in the mid 2000's, not bad little cars but I have never liked three cylinder engines.
