InTheCube
Hi.
I have a Netgear WNR2000 router (4 ports + WAN port + WiFi), of which the WAN port is connected to my iBurst desktop modem via an ethernet cable.
Now I am finally switching to ADSL, and I need to know if I can buy a simple ADSL modem (with no router, WiFi, etc) and connect it to my existing Netgear WNR2000 router in the same way that my iBurst is connected?
I believe that the router establishes a PPOE connection with the iBurst modem - is this correct? If so, will the router be able to do the same with an ADSL modem?
If not, then which modem/router combination would you recommend?
