Dipro
I am considering using CellC on Openserve, but I have a concern about installation, which I am hoping that someone can answer for me.
CellC's T&Cs state:"Please note that installations on the Open Serve network are limited to 8 metres, the customer will be liable for any installation over 8 metres at a rate of R 182.40 per linear metre."
.... and I am definitely going to be on Openserve.... now 8m will take it into my garage... and based on this installation example: https://techcapetown.co.za/2015/05/1...*-telkom-ftth/ ... this will suffice until the Fibre Modem (which doesn't need a power source). Then it would require a Cat5e or preferably a Cat6 ethernet cable to my router, which would be about 15 to 20 metres away.
Now, my question is: do I pay R182.40 per metre of ethernet cable too ? .... because I do have my own cabling. But is it literally my only concern.... if anyone does know the answer to this, I would appreciate the feedback
