Hi there,
Im having a problem with this stupid ISA vpn. People can connect to the VPN no problems... but once connected they cannot access any of the internal network.
this is the error alert it gives me :
Alert Information
Description: ISA Server detected routes through the network adapter Local Area Connection that do not correlate with the network to which this network adapter belongs. When networks are configured correctly, the IP address ranges included in each array-level network must include all IP addresses that are routable through its network adapters according to their routing tables. Otherwise valid packets may be dropped as spoofed. The following ranges are included in the network's IP address ranges but are not routable through any of the network's adapters: 192.168.1.73-192.168.1.73;196.6.122.0-196.6.122.255;192.168.0.2-192.168.0.9;192.168.11.13-192.168.11.13;196.35.119.1-196.35.119.1;196.35.119.75-196.35.119.75;. Note that this event may be generated once after you add a route, create a remote site network, or configure Network Load Balancing and may be safely ignored if it does not re-occur.
So yes i gather its a routing problem but the thing is we have changed nothing but yet now it wont work ?
Any ideas/help would be much appreciated.
Alert Information
