LG G3: Screen and Battery Issues
Zertop
Hi There.
I would just like to know if anybody has experienced a slightly yellow tint, as well as issues with battery life on some LG G3s. Compared to my friends G3 (as shown above), my screen is slightly yellow - and my battery life is incredibly limited. He has used his phone on full brightness for 1hr30m, whilst I have used mine on 70% brightness for 35m, and we both have the same battery percentage left.
That surely cannot be correct? Only difference is that I am on MTN, and he is on Vodacom. Would lack of signal sometimes during the day make that much of a difference?
Other than that, app syncing etc is the same.
Do a factory reset and see if the problem persists.
My battery life used to be brilliant then all of a sudden it took a dive.
I went back to stock 4.4 on Sun, then upgraded to 5 again. Battery is once again solid and lasting forever.
Maybe I should try this.
Thanks Mike.
Z
When I'm in poor signal areas I just turn my mobile data off and my battery stops dropping. Unless it's at your house?
I traveled to the UK a few weeks back and had the same issue with battery life. Seems that any signal related issues causes really bad battery drain.
