Innuendous
- Nov 30, 2012
Hi
I am looking for some insight into issues I have been having.
First some background info...
I have an Afrihost 10 mbps uncapped account since July 2012. Since then I have had a more or less constant download speed of 8.50 mbps 24/7 (saix.net speed test) and my line has been syncing at 10 mbps.
Even on torrents I get over 900 KB/sec.
About 2 weeks ago I started experiencing extremely slow and drastically fluctuating speeds from 0.95 mbps to 3 mbps but only between 8pm and 11pm every night. Even normal web browsing is slow. I called Afrihost many times but got nowhere.
I was eventually given a capped account to test with. The capped account performed perfectly even at the times when I was experiencing slow speeds on my account and Afrihost assured me that I was not being throttled.
2 days ago, while on the phone with Afrihost, my speed was dropped in order to test the signal-to-noise ratio. This dropped my download speed to 6.30 mbps. I have since requested that it be brought back up to 10 mbps which Afrihost attempted to do.
The problem is that now my line only syncs at 8 mbps (8128 downstream max rate on the router) and Afrihost says that it is because the SNR is too low. (But from its inception the sync rate on the line has always been 10 mbps). I am now only getting a download speed of 6.30 mbps.
Does anyone have any idea what could be causing these problems or what the solution is.
