Matrix Warehouse Universal Laptop Charger.
Zuner
In a pineapple under the sea..
Hi Forumites
So i have this friend, who purchased a universal laptop charger from matrix almost a year ago.
Yes i know mistake #1 Matrix #2 Universal charger.
Now that that's out of the way, the problem we are having is that their psu's keep blowing. In a 1 year period 3 have blown, he says they keep getting hot and then blowing with sparks coming from the psu. The original factory psu is 19v 3.42 amps, and the universal is among others 19v 4 amps. we've stress tested a psu borrowed from another friend which is a Liteon 19v 3.42 (non original) as one argument the store had is that the battery is shot and pulling too many amps. This borrowed charger has been running fine for over a week now without even getting warm whereas in a test done at the store with a universal charger they tested playing hd movies and the charger got quite hot as noted by a staff member.
We've just come from a shouting match at out local matrix cause my friend is now tired of the crappy chargers and wants his money back since replacing it with the same charger which gets hot and pops is pointless, but suddenly now they saying it was user damage and the cables were torn at the psu output (a story which is BS that they're spinning off the truth which is the ORIGINAL factory psu died in that way not the universal one.) so they definitely won't give money back as its been almost a year.
We're now waiting on head office to reply after "testing" the "faulty"(Rubbish) psu.
Let this be warning to those considering buying a universal laptop charger..
What are your inputs?
Three blown chargers of the same type, this is a horror story! Every time charger blows up it is a serious risk of permamently damaging laptop. Your friend should ask them whether they accept liability. If they do, they must put it in writing. Also remember that every replacement extends warranty for one year.
Bought and sold many, many universal chargers from Matrix over the last ten years. Never had a single come back.
I would investigate the draw on your friend's laptop, or his DB Board.
I popped one on my mom's laptop about a year ago. They replaced it and it's been going strong for over a year now. Get SUPER hot though.
Extensive load will normally trigger overload condition, resulting lockup or dropping output voltage (depends on the model). Not a failure.
The guy actually made a point of saying it does NOT extend the warranty after each come back and replacement with a new unit. thats a good point, if they insist of replacing it again we'll include the liability in the talks..
The draw is fine as mentioned a proper Liteon replacement charger works fine. not even getting warm and is also rated for less watts/amps than their universal.
Also the device got hot in a few minutes testing (with a brand new unit) at the local matrix store.
the super hot part worries me. surely it couldn't have been designed to get that hot under normal use?
yeah and the failure by the way my friend puts it is quite spectacular..
rather get a generic or original that has been designed to support the laptop you have.
yeah thats what we want to do now but he wants his money back since they cannot supply a product that actually works..
Universals are for when your laptop is obsolete.
we've stress tested a psu borrowed from another friend which is a Liteon 19v 3.42 ~ This borrowed charger has been running fine for over a week now
There's your solution.
This is what they say, but but it is illegal. Unless it is stated on the invoice, replaced unit receives a full warranty from the time you received it.
What it means to you. You are correct demanding money back.
- post on Hello Peter.
- Small Claims Court at your district. You don't need a lawyer and entire procedure is very simple to follow.
BTW, Do you still have old charger? You mentioned torn cable. It could be easy to repair by replacing cable.
- Small Claims Court as your district. You don't need a lawyer and entire procedure is very simple to follow.
I'll inform my friend. I was also thinking hello Peter, was waiting for the response from their head offices.
It could've been, if the old charger weren't destroyed when it was opened to inspect the problem.
I don't get it. It is usually sealed or glued unit to prevent user access (and electric shock).
yeah it is, which is why it was destroyed trying to open it up. the cable had come loose inside the unit. i guess the strain relief wasn't strong enough. i see on bidorbuy there are a few better options. ( i bought my HP charger off there about 3 years ago).
^This. And it is HP plug with a thin pin inside. A typical fault. It wasn't destroyed during opening, it is typical fault. I can post picture how I fixed my HP power pack. :)
You can still fix it, but if you follow Rickster's post, it should cost R200.
