MR3420 and Huawei E1820 is not working....pls help
KingPhemelo
Hi I am currently using MR3420 and also E1820 and cant seem to be getting it right.
i have upgraded today the router with latest firmware......but the router seems not able to pick the 3G .....I am using 8ta as the network
the router logs
1st day 00:17:04 DHCP NOTICE DHCPS:Recv INFORM from 08:11:96:ED:B5:80
1st day 00:17:06 3G INFO 3G Modem vendorID: 0x12d1; productID: 0x1446
1st day 00:17:09 3G INFO Switch modem mode with the 0 command in the file usb_modeswitch.conf
1st day 00:17:14 3G INFO Switch modem mode with the 1 command in the file usb_modeswitch.conf
1st day 00:17:24 3G INFO Switch modem mode with the 2 command in the file usb_modeswitch.conf
1st day 00:17:26 3G INFO 3G Modem vendorID: 0x12d1; productID: 0x1446
1st day 00:17:27 3G INFO Switch modem mode with the 3 command in the file usb_modeswitch.conf
1st day 00:17:36 3G INFO Switch modem mode with the 4 command in the file usb_modeswitch.conf
1st day 00:17:43 3G INFO Switch modem mode with the 5 command in the file usb_modeswitch.conf
1st day 00:17:57 3G INFO 3G Modem vendorID: 0x12d1; productID: 0x1446
1st day 00:17:58 3G INFO Line 264: Switch 3G modem mode failed
1st day 00:17:58 3G NOTICE Switch 3G modem mode with the command file: /etc/usb_modeswitch.d/12d1_1446
1st day 00:17:58 3G NOTICE File /etc/usb_modeswitch.d/12d1_1446 is found, switch 3G modem mode with the command file, switch cmd: usb_modeswitch -v 0x12d1 -p 0x1446 -I -W -c /etc/usb_modeswitch.d/12d1_1446 &
1st day 00:28:18 DHCP NOTICE DHCPS:Recv REQUEST from 08:11:96:ED:B5:80
1st day 00:28:18 DHCP NOTICE DHCPS:Send ACK to 192.168.1.100
1st day 00:30:10 DHCP NOTICE DHCPS:Recv INFORM from 08:11:96:ED:B5:80
1st day 00:41:16 DHCP NOTICE DHCPS:Recv REQUEST from 08:11:96:ED:B5:80
1st day 00:41:16 DHCP NOTICE DHCPS:Send ACK to 192.168.1.100
1st day 00:41:40 DHCP NOTICE DHCPS:Recv INFORM from 08:11:96:ED:B5:80
Firmware Version: 3.12.19 Build 110617 Rel.39329n
Hardware Version: MR3420 v1 00000000
has anybody got these setup working....pls
Hi there,
If you put the modem into a PC/Laptop does it connect to the 8ta network?
There is plenty of evidence on this and other sites that this combination does work but coverage from your network maybe the problem
I would suggest that you try it in another area to see if it connects there. All the cellular providers have areas where the coverage is not as good as they would like and you may be in one of those area.
Let us know how you go.
Regards
Tim
I am using exact same setup from last 1 year without any problem.
mr3420 router
cellc E1820 modem
8ta 10gig special.
Everything is working fine for me. I did not even update the firmware on the router from the time i bought it 2 years back.
i
Thanks Guys for the replies .....i borrowed my friend's Huawei router and plug in my sim and not a single disconnection....the connection has been running from last night till now.....so the 8ta connection seems fine...
i hear on some forums sayin this E1820 sometimes gets too hot and disconnects... so at the moment I am not sure whether the problem is the router or the 1820 modem?
