Need help with COD4 cvar rate.
Jtkiller
Hi. I keep getting kicked on SGS by punkbuster, with a message saying cvar rate must be under 25000. I type /rate 25000 in the console and I still get kicked. Can someone tell me how to fix this please ?
Well you could try change the setting in your profiles\{user name}\config_mp.cfg file.
Change seta rate "25000" to seta rate "15000"
The problem is that your rate is to high (25000) as SGS have set the server rates to 15000.
Join a game and before joining or choosing sides open your console (by using the ~ key) and type
Code:
\rate 15000
and enter. No more pb kicks.
And remember if you play on a clan server running promod it ups your rate to 25000 automatically so when you join a normal pub server you will need to change it to 15000 again.
Hi everyone,
Just an interest question because I have the same problem.
What is cvar rate and why does it effect online play?
IIRC it's got something to do with the amount of data (bits/bytes) your machine can receive per second. (Obviously this would also be affected by your line speed). With a fast line, you could get the full 25000 while a mate with a slower line might only get 5000. I guess this gets set by server admin to counteract any advantage you might gain by this, and level the playing field somewhat. (Seem to recall it was 8000 when I first started CoD4 and promod upped it to 15000.)
