OSCommerce Problem
charlie_82
Johannesburg
Hi all knowledgeable ones!
Please help me...
I downloaded this template: http://how2make.blogspot.com/2007/05/free-oscommerce-template-jewellery.html
I've managed to get it installed but the categories do not display properly... It just shows a bunch of code.
Same goes for the language & currency options etc
You can take a look here http://mybroadband.co.za/photos/showphoto.php/photo/5598/size/big/cat/500
There seems to be a code problem somewhere cos there's a couple of ">" all over the page...
looks like the php shorttags problem. Whats your server setup?
I'm running WampServer 2.0
I've run a few other templates without this issue, including the original OSCommerce...
Here's my code, I haven't made any changes to the original:
Code:
<?php
  $Id: categories.php,v 1.25 2003/07/09 01:13:58 hpdl Exp $
  osCommerce, Open Source E-Commerce Solutions
  http://www.oscommerce.com
  Copyright (c) 2003 osCommerce
  Released under the GNU General Public License
  function tep_show_category($counter) {
    global $tree, $categories_string, $cPath_array;
    for ($i=0; $i<$tree[$counter]['level']; $i++) {
      $categories_string .= "&nbsp;&nbsp;";
    $categories_string .= '<a href="';
    if ($tree[$counter]['parent'] == 0) {
      $cPath_new = 'cPath=' . $counter;
    } else {
      $cPath_new = 'cPath=' . $tree[$counter]['path'];
    $categories_string .= tep_href_link(FILENAME_DEFAULT, $cPath_new) . '">';
    if (isset($cPath_array) && in_array($counter, $cPath_array)) {
      $categories_string .= '<b>';
// display category name
    $categories_string .= $tree[$counter]['name'];
      $categories_string .= '</b>';
    if (tep_has_category_subcategories($counter)) {
      $categories_string .= '-&gt;';
    $categories_string .= '</a>';
    if (SHOW_COUNTS == 'true') {
      $products_in_category = tep_count_products_in_category($counter);
      if ($products_in_category > 0) {
        $categories_string .= '&nbsp;(' . $products_in_category . ')';
    $categories_string .= '<br>';
    if ($tree[$counter]['next_id'] != false) {
      tep_show_category($tree[$counter]['next_id']);
<!-- categories //-->
          <tr>
            <td>
<?php
  $info_box_contents = array();
  $info_box_contents[] = array('text' => BOX_HEADING_CATEGORIES);
  new infoBoxHeading($info_box_contents, true, false);
  $categories_string = '';
  $tree = array();
  $categories_query = tep_db_query("select c.categories_id, cd.categories_name, c.parent_id from " . TABLE_CATEGORIES . " c, " . TABLE_CATEGORIES_DESCRIPTION . " cd where c.parent_id = '0' and c.categories_id = cd.categories_id and cd.language_id='" . (int)$languages_id ."' order by sort_order, cd.categories_name");
  while ($categories = tep_db_fetch_array($categories_query))  {
    $tree[$categories['categories_id']] = array('name' => $categories['categories_name'],
                                                'parent' => $categories['parent_id'],
                                                'level' => 0,
                                                'path' => $categories['categories_id'],
                                                'next_id' => false);
    if (isset($parent_id)) {
      $tree[$parent_id]['next_id'] = $categories['categories_id'];
    $parent_id = $categories['categories_id'];
    if (!isset($first_element)) {
      $first_element = $categories['categories_id'];
  if (tep_not_null($cPath)) {
    $new_path = '';
    reset($cPath_array);
    while (list($key, $value) = each($cPath_array)) {
      unset($parent_id);
      unset($first_id);
      $categories_query = tep_db_query("select c.categories_id, cd.categories_name, c.parent_id from " . TABLE_CATEGORIES . " c, " . TABLE_CATEGORIES_DESCRIPTION . " cd where c.parent_id = '" . (int)$value . "' and c.categories_id = cd.categories_id and cd.language_id='" . (int)$languages_id ."' order by sort_order, cd.categories_name");
      if (tep_db_num_rows($categories_query)) {
        $new_path .= $value;
        while ($row = tep_db_fetch_array($categories_query)) {
          $tree[$row['categories_id']] = array('name' => $row['categories_name'],
                                               'parent' => $row['parent_id'],
                                               'level' => $key+1,
                                               'path' => $new_path . '_' . $row['categories_id'],
            $tree[$parent_id]['next_id'] = $row['categories_id'];
          $parent_id = $row['categories_id'];
          if (!isset($first_id)) {
            $first_id = $row['categories_id'];
          $last_id = $row['categories_id'];
        $tree[$last_id]['next_id'] = $tree[$value]['next_id'];
        $tree[$value]['next_id'] = $first_id;
        $new_path .= '_';
      } else {
        break;
  tep_show_category($first_element);
  $info_box_contents[] = array('text' => $categories_string);
  new infoBox($info_box_contents);
            </td>
          </tr>
<!-- categories_eof //-->
Oh hey, nice one Kloon! I enabled "short open tag" in php and it's displays correctly now. Pity the design itself is still off tho :(
