Jay Simlian
- Mar 21, 2018
advice received, thanks so much everyone
I just linked them as a guideline for the price, you should also see the options for the extra components you want to add and it will give you an idea of what you can afford.yeah, might be the certain company I am trying to avoid, thanks for the advice though. appreciate it. I should probably look into more ram yeah
His budget is 10/12K max . He plays Sims 4.32 GB ram and a Graphics card with 8gb of RAM on it would do. Also remember, SSD (doesn't have to be 1TB) so any rendering you do is quick and a few TB of storage for the actual video files after.
aahhhh!! I am the worst with waiting but will probably regret not. I do have a licensed copy of windows 8, Just gonna have to try get it on a usb (think you can do that on windows's website if you have a serial code) because I feel adding a dvd writer is a waste and totally pointless in today's day and age.
Complete overkill for his requirements.32 GB ram and a Graphics card with 8gb of RAM on it would do. Also remember, SSD (doesn't have to be 1TB) so any rendering you do is quick and a few TB of storage for the actual video files after.
