problem in how to share connexion between 3 pc's
smileboy003
Salam, well my problem for today is how to share connexion between 3 pc's exactely as you see in the pic..
i can't move anything , in room 1 i have router and one pc and can't add switch or any pc.the switch is in room 2
so if my my stuff sit right, i wanna ask wich cable should i use between it. straight cable or cross cable
thanx so much
Regular convention would say straight cable, but modern switches will probably auto-sense as the dude above said.
so i can use cable RJ45 straight one? note the switch i have is D-Link DES-1005A 5 PORTS SWITCH
is there any configuration should i use in other pc's?
thank you
that's nice, but is there any thing should i change in network option, the net comes automatically?
no that's not what i mean, because i had 2 pc before without the switch and everything's ok, so when i want to add another pc, in the room 2, then i had to use a switch, the ISP config is ok.
Should just be as easy as plugging the network cables in and checking the PC's are set to "obtain address automatically" assuming the DHCP option in the router is enabled.
