Problem with updating router firmware
JJRM
Hi guys,
Has anyone had any success with updating the firmware on the Zyxel P-2602HWL-D1A router [Current firmware: V3.40(AUJ.0)b4 | 06/21/2007]? I get some kind of "rompager" error. Router keeps on cutting out and restarting every now and then...thus dropping all connections. After a couple on minutes..everything's working again.
Unfortunately the online zyxel support page doesn't work all that well...not even possible to send a support request. Their forum page looks like it's down so no help there.
Wondering if you guys had any success. It was a Telkom supplied router a couple of years back. Are you aware of any tools that could help me do this?
I had one of these routers a few years back try to telnet into the router then delete the firmware and reflash it and that should fix the problem
Thanks solidsnake, I've never flashed a router via telnet before. Can you tell me how to do it? Googling didnt help too much unfortunately.
Great. Thanks Solidsnake. Dropped you an email...
