Repeat Horizontal AND Vertical in Dreamweaver...
PHTech
Witbank
Hi there...
How do I set a repeat region in Dreamweaver CS3 to do a repeat for example: To space 35 thumbnails in one page, which limits the collumn count to 5 collumns, and fit the rest into rows...?
Is there perhaps any free extension to do this type of thing...? To have an example you can think of it as an Online Catalog, where you can view products on one page, and then click on one of them to view the details...
ANY HELP would be appreciated...!
Thanx...!
I'd say ditch Dreamweaver and get to grips with CSS, ASP.NET and Javascript. Then download Visual Web Developer 2008 Express edition (FREE) and do all your coding in there. ;)
I have been using Dreamweaver for a while now, and the thing is, I am not too great with Handcoding... Dreamweaver usually have nice plugins and extensions to do such stuff...
So personally, I want to stick with Dreamweaver...
Well, best of luck then. I've tried my hand at Dreamweaver and it takes me 3 times longer to get the exact same results that I could've coded by hand. If you want any help with the "handcoding" though, don't hesitate to contact me!
Is there then some way to take the code of a normal repeat region in DW and change that code to accompany what I want it to do...?
Thanx...
