I would like to make my house lights smart and controllable from Home Assistant, etc.
So far I've summarised the no neutral options available locally as follows:
The possible issues with Shelly 1L/Dimmer 2 include:
Update 1: Added Shelly Dimmer 2.
Update 2: Added alternate EACHEN pricing.
| Shelly 1L | Shelly Dimmer 2 | EACHEN L-RF-US | Tuya Smart Light Switch | |
| App | Shelly Cloud | Shelly Cloud | eWeLink | SmartLife/Tuya |
| Cloud/LAN support | Cloud and/or LAN | Cloud and/or LAN | Cloud & LAN | Cloud & LAN |
| WiFi - 2.4GHz | Yes | Yes | Yes | Yes |
| RF - 433MHz | No | No | Yes | Yes |
| Capacitor | Shelly Bypass ($) | Shelly Bypass ($) | Included | Included |
| Dimmer | No | Yes | No | No |
| Power usage measurement | No | Yes | No | No |
| Tactile feedback | - | - | No | No |
| Double tap/long press support | - | - | No (???) | No (???) |
| Home Assistant support | Shelly (CoIoT) | Shelly (CoIoT) | SonoffLAN (HACS) | local tuya (HACS) |
| Chipset | ESP8266 | ??? | ESP8285 | ??? |
| Tasmota firmware upgrade | OTA & Serial | ??? | Soldering required | ??? |
| ESPHome firmware upgrade | OTA & Serial | OTA & Serial (in dev) | ??? | ??? |
| 1 gang cost | R 201 (11.58€) R 216 (12.42€) with Bypass | R346 (19.90€) R ??? (???€) with Bypass | R 340 / R 312 | R 420 |
| 2 gang cost | - | - | R 370 / R 337 | R 450 |
| 3 gang cost | - | - | R 405 / R 405 | R 480 |
| 4 gang cost | - | - | R 435 / R 425 | - |
| ICASA Type approval | Yes | Yes | Yes | No |
| NRCS approval | Pending | Pending | Pending | ??? |
| SANS (IEC) 60669-1 | ??? | ??? | ??? | ??? |
- Coming soon, used EU pricing as a guide.
- No physical light switch included, need to reuse the existing light switch or replace with a button.
- One device and bypass required per gang.
- Possibly no space behind the light switch to install multiple devices.
