Some Internal Routing help.
Gtx Gaming
Gtx Gaming
cape town
Ok so i added new Device to my network , that supplied for the adsl research project.
The new device is Netgear N600 Wan router running OpenWRT on it.
I will be setting up Ucap on the netgear n600 later on , that's why i want the devices plugged into it instead of my switch.
Ok now for the problem:
I want my pc to plugged in on the netgear N600 and be able to access my download pc.
My devices and i.p's on it.
Adsl Router:
192.168.1.1
Cable going from there to my 8 port switch.
DHCP is running on here.
Mikrotik SXT:
172.18.122.190 (it needs this to connec to the wug ) Plugged in to my 8 port switch , will stay there)
This is setup with NAT though my adsl router , every device that has thisas gateway has internet access.
Download server :
172.18.122.185/29
Gateway:172.18.122.190
DNS:172.18.1.1 and 192.168.1.1
2nd I.P on he same NIC.
192.168.1.20
255.255.255.0
(will stay on the switch)
Netgear N600
Get The i.p from the adsl router.
Wan port used for internet access.
Plugged into the Switch
Main pc ( this one needs access to the download pc)
192.168.1.68
255.255.255.0
Gateway: 192.168.1.1
Currently plugged into the Netgear.
2nd I.P: Same NIC
172.18.122.187/29
So To sum it up.
Unmanaged Switch Connects the adsl Router , SXT ,netgear n600 and the download pc atm.
The pc can access the Download server fine , when plugged into the switch , but then ucap wont measure my usage . So somewhere i need to add a route or something to access the Download pc.
Hope someone can help me :P
