480 Mbps IIRC..How fast is USB 2.0 at this stage ? (Too lazy to google)
Soon we can boot into USB flash-drive ... True mobility. Yaaaay.
there are Wireless USB devices out there already; USB 3.0 is a different standard.
@Turiko, you chose that field... I doubt a 8bit micro would be able to handle those data rates. I also think that USB 3.0 is backward compatible.
Sure, if you have a 32GB flash... Vista wants at least 16GB... 16GB flash is 15GB in size. Also, the larger the flash the slower it gets. That's one thing I hate about my multi-gig flash. It's much slower than my 64MB flash drive was back then.
Will the flash memory be able to sustain multi gigabit speeds or will we plug in a 3.0 flash drive or iPod and find that the speed is exactly the same?
Most likely. If you look at the current specs, only very few flash drives can write faster than usb 1.0 never mind anywhere near to usb 2 speeds
