Having never even witnessed a system being built before, this might be a stupid question, but...
I have the Asus P5Q board and a Coolermaster Cosmos. The board came with no screws but the case has a bunch. However, the screws have like a wider shoulder section between the flat part and the end. So I can screw the board into the spacer but once the shoulder reaches the board that's as far as it goes. That means the flat part doesn't reach the board. It's just sticking out a good 5 centimeters or so.
Surely that can't be right?
Do I need to find different screws?
