Telkom LTE
blueboy
I previously used the B593 via Afrihost but decided to go the Telkom LTE uncapped route
I applied for the Telkom LTE Uncapped and received the B315. Connected it directly to my laptop and works fine but when I try to access the internet via my Netgear switch and the B315 does not "see" the switch using the ip address of the B315
Then inserted the Telkom sim into the old B593 and it worked immediately via the switch.
Are there some settings that need to be applied or material that I can be referred to?
I suspect Netgear is not working as a switch, doing some routing. The only difference is default router IP address. Change B315s IP to 192.168.1.1, it will be the same as for B593.
It is difficult to say what is wrong having so little information from you.
