W@P
- Sep 10, 2007
I am planning on upgrading and would like to know what you guys think.
Plan on getting:
Core2 E6550
ASUS P5K LGA775 mb (not deluxe or wi-fi one)
Asus EN8600GT (one with the fan)
And i curently have 1gb DDR2 667 normal memory plan replacing that a bit later.
And i also have a 350watt aopen psu, should i buy a bigger and better one thats got the cables for PCI-E, if so, wich one ?
Also should i upgrade the ram and which ram should it be then?
Will use it mostly for midrange gaming and movies and so.
Not too much worried about overclocking cause i don't know how.
Just want the system to be future proof for a while.
Thanks in Advance
Plan on getting:
Core2 E6550
Thanks in Advance
