Using a WiFi range extender to the house
GregH991
Johannesburg
I have an ASUS Ac52U WiFi router that runs on 2.4 and 5 MHz frequencies. It is set up in the lounge where the Telkom landline comes it
I take it you want to extend the wifi from there?
you can try a wifi extender - put it just on the edge where you lose signal and see how you go from there.
Personally I would recommend running a cable to a 2nd WAP where possible and only use extenders if there is no way to run a cable.
Sorry I only posted half my question before hitting enter. Then posted the full question as a separate post. Sorry admins, my bad. This one should be deleted...
