Venom Maker
Why is my line only syncing at 14Mbs if the Max Rate available is 26Mbs. When I first had my line upgraded to VDSL I was syncing at 20 Mbs and gradually the speed has dropped to 14Mbs and settled there
Downstream Upstream
TCM(Trellis Coded Modulation) On On
SNR Margin 12.0 dB 6.1 dB
Line Attenuation 25.2 dB 65.0 dB
Path Mode Interleaved Interleaved
Interleave Depth 1659 69
Data Rate 14333 kbps 1846 kbps
MAX Rate 26008 kbps 1981 kbps
POWER 14.3 dbm 5.4 dbm
INP 2.3 symbols 2.6 symbols
CRC 2417 42
Downstream Upstream
CRC 2417 42
