Vega 56 OC help
Ulquiorra
Hi peeeps of MYBB!!
I recently bought a vega 56 reference card, and flashed its bios to vega 64 bios. Was very easy to do and also successful.
I then proceed to OC my card a little bit more, as a lot of people can do it without touching the volts even.
By applying only a +1% on frequency, memory from 945mhz to 1000mhz, and power limit to +50%.
After doing this when i open heaven benchmark it says my gpu freq is at 2400mhz and my memory at 1500mhz. It also bombs out immediately, restarting my pc. Gpu-z shows the frequencies at where it should be. I am very confused. And when i change the oc back to stock settings, heavens benchmark is still at 2400mhz for gpu and memory 1500mhz. Only after restarting pc does it revert back to normal.
I can't find anything on the net explaining that wrong frequency readings in heaven benchmark.
Any help will be appreciated!
Hi peeeps of MYBB!!
Unigine dont report accurate clock speeds, rather use msi afterburner & riva tuner statistics server.
Thx boys, i believe the gpu just got over hot real fast - i'll have to look into getting either a waterblock or aftermarket cooler.
