Ventoy (easy Multi OS installations on one USB)
dualmeister
Came across this gem.
There are other tools to create multi-OS installation USB flash drives (such as Yumi).
However, Ventoy works differently. You install it once onto your flash drive after which you just dump the ISO images as they are whether it be Linux or Windows. There are a list of supported / tested ISO's though.
Check it out.
Ventoy
Supported ISO images
