Potion
Why anyone would want to host with MWeb is a mystery. No control panel, hellishly expensive, and they hijack domain ownership by making themselves the billing, technical and admin contacts on the whois records at Uniforum.
MWeb, like many other large hosting companies (e.g Hetzner and WebAfrica) and ALL of the cell phone service providers, have prehistoric or overly complicated rules and procedures to terminate service, which I have no doubt are deliberately put in place for one of two reasons:
1. The '-ations'... Prevarication, Obfuscation and Procrastination. The logic behind this is to frustrate the client so that, either the process becomes drawn-out into at least the next billing cycle and they can exact an additional month or two's subscription out of you. Or else you simply abandon the process because its just too damn hard and time-consuming and you convince yourself that it isn't so lousy (you're wrong, it is!) and just stick with them.
2. To protect themselves from the general incompetence of their own staff who - surprise! - are as inept as they are underpaid. Yep, substitute competence for systemised business rules.
So the last time I embarked on this journey with MWeb, I decided to do it by the book. I called them and spoke to Fahid, who set out the procedure... Get the domain owner - the Mweb account holder - to fax them a letter requesting Cancellation For Transfer and for MWeb to accept the transfer request, and also send the photo page of his/her ID document. Huh? FAX! It's 2011 Fahid - who has a fax machine?! "You can scan it and use email-to-fax or just email it directly to [email protected]." Okay then...
The letter was duly drafted and sent by the designated account holder, and off to coza-admin went the domain Update form. "I did exactly as they asked, It'll work this time" I thought. But no, after the obligatory 24 hour voting window I get...
Every time a coconut! By NOT doing anything at all MWeb had foiled the process. And around we go again. If I had a buck for every time...
Let this be a warning to anyone considering hosting with MWeb, or any of the other dinosaurs. Just don't do it. There are hundreds of smaller hosting companies whose angle is to keep your custom with excellent service, 21st century technology and value for money. Go with them instead. They won't resort to the MWeb dirty tactics: Own control of your IP, make it hard for you to get back control, and cut you off if you're late (without the courtesy of calling first, just to make sure the error wasn't theirs). Wouldn't you prefer someone who calls YOU 30 seconds after you've logged a support issue on their website. And when you call them you get to speak to the bloke who built the systems, not some out-of-his-depth-call-centre-tron.
Rant Over...
The domain Update application for X.co.za has been rejected.
No votes were received.
Rant Over...
