Wifi timer switches for pool pump and wellpoint pump
rh1
Somewhere close to you
Hello
I dont have any home automation, my timer switch on my pool pump packed up. So thinking of buying a switch with wifi.
What would be a good purchase, the timer switches will be in fibre enclosures outside, so there is that consideration as well.
How is the wifi reception there, these switched normally does not have the strongest antennas.
  • Like
Reactions: rh1
The source for both electric cables (power supply) is the same area, I could put a weather proof box there which is very close to one of my mesh units.
Then the power goes to straight to the pumps.
I have a few of these:
Simple enough, just works. One is 15m from the house inside a plastic outdoor housing and no issues.
  • Like
Reactions: rh1
This one?
Correct. Currently using for geysers and pools pump and very happy with performance.
  • Like
Reactions: rh1
This one?
Just remember that one takes two slots/spaces on your DB board/pool DB board. so makes sure you have the space
  • Like
Reactions: rh1
