freematrix
- Mar 7, 2007
Hi,
Looking for advice on a media player that is wireless that can be plugged in via HDMI into the back of my TV.
It does not have to have a hard disk in by I would like to connect to a network share over the wireless.
Other options would be external USB connections.
I have seen iOmega and Netgear devices and also the PS3 (a bit to big).
There is also the Apple TV but I am not sure with the Airplay and iTunes the success I will have.(As long as it plays in iTunes it should play on the Apple TV???)
All advice or recommendations welcome.
