wireless Router intemittent connectivity issue
amer
Hi Everyone,
I have got an Huawei HG8245 wireless router with 40 mbps optical connection on it and as we are in the same room as of the wireless router itself we are connected through wifi and the issue is that when i ping to the Ip address given to the router i.e., the Default gateway there is a intermittent connectivity issue once the packets are recieved and thrice the Ping response is "Request timed out" and same cycle goes on....unless i reboot the router and in every two to three days i have found that the router reboots itself.
I cannot let that go on as the telecommunication of my office is also through that very huawei router.I had the config file downloaded when i previously have done the configuration i again uploaded it and rebooted the router after which the pings were being responded or acknowledged but like after 5 to 10 minutes again its the same issue and at times the connection automatically gets back to normal and again it goes the same as described above.I dun think its a wifi issue as wifi is only being disconnected when the router is rebooting itself or the router is rebooted manually.Honestly i think the issue with the routing protocol deployed on the router by the service provider cox its not that all the system experience the this issue all at once..when my colleague experiences it i do not and vice versa where as we are all connected wirelelssly and we are all in the same DHCP pool.
Any asistance would be really appreciated in this regards.
Regards,
Amer.
Hi There,
If this is a new device I would ask the provider to test it as it sounds to me that it may be faulty.
Is it only WiFi connections that fail or does it also fail on cable connections?
Regards
Tim
Hi everyone,
The issue is now resolved...the crashing was due to the telephone lines not configured properly and the Request timed out was the wifi and the routing protocol issue deployed on the huawei router....the huawei router was changed by the Vendor and i gave LAN connectivity to all the users in the office hence resolving the issue.
