4G LTE Medium Gain Antenna
CoolBrian
Hi Guys
I rent an apartment and I have tried sending requests to mobile operators coz my reception is bad. I wanted to find out if these gain Antennas are good or any that comes highly recommended
Xpol0001 or Xpol0002 antenna's are supposedly quite good.
If you accept half of theoretical maximum LTE speed (without MIMO), normal 3G antenna will work. There are wide bandwith window monted 7dBi patch antennas available, it should easy to install.
