Sparky862
Yep, me again. I have the Skyworth Binge Android Box. It came pre installed with DSTV and SHOWMAX.
Problem I have is that when I change the video quality to 1080p, the image still looks 480p. I have checked that in the settings menu it is adjusted to stream at 1080p and also when I click on the cog wheel while watching a movie, it also shows that the highest setting is selected which is 1080p.
In my Skyworth Binge Box settings, I have set SDR to HDR on AUTO (You can either select Auto or Off). And I have set HDR to SDR on OFF (You can either select AUTO, ON or OFF).
So what gives here? Why is my box not streaming 1080p?
Youtube streams fine otherwise and streaming at its true quality it is set to.
