Bluescreen Issue - Help Needed.
RVR
Durban
I've been struggling with this bluescreen on my windows 7, I've tried system restore but didn't fix it, I even Uninstalled and reinstalled my Nvidia GeForce driver.
When i use the pc on safe mode it seems to work fine so I'm not sure.
Any fix I can try?
Here are the images of the error.
Test it with another power supply.
Upgrade that sucker to 10!
Good chance it'll sort out the issue by the by, blue screens can be a serious pita to troubleshoot.
The free Windows 10 update is no longer available :/
Managed to find the windows 10, will check if it fixes the BSOD
This! Also check that memory are seated properly, etc. Just open the box up and poke around if it's a desktop. If it's a laptop then you have to hunt down the culprit driver causing this and you have to know what your specs is like before hand to check with a bootcd like Hiren's Bootdisk. :)
Memory is fine, it's definitely a driver issure I assume.
Is it a laptop with a 3G card? Mine started doing that last year, removing it sorted it out.
It has the most chance to solve your problem than all the other solutions. It's almost as good as "Have you tried switching it off and on again?". Good luck! :)
Thanks man, i'm hoping for the best.
