Car fast charger
IssiAmd
Need a car charger for both Huawei and Sammy.
The few I checked on TA were Qualcomm certified, will this fast charge a huawei as well?
Don't need supercharge speeds just not slow charging.
Feedback appreciated
Romoss sells a good one on Takealot for under R200 last I checked.
Fast charging isn't really good for the health of your battery over time, I would charge at max 2 Amps but I personally use a 1 Amp charger in my car from RS Pro.
You realise fast charging ramps up the voltage, not the amps?
I got a 2 output usb car charger, 2A and 500ma nogal, but when one charge two phones at once, there is not enough woema.
If you can wait a while, order a Blitzwolf charger from Bangood. I have several. They make a good quality product
Of course it outputs more amps, one im looking at (Huawei Super charge) says 4.5V @ 5A or 5V @ 4.5A
Huawei do that with their special charging system but the QC spec is higher voltage and parallel charging via 12v 9v 5v 18w total
Also need one with fast charge 25watt, but even normal plug one seems be hard to find at decent price.
Most them only say fast charging when i plug them in, only the original samsung one I have does super fast charging on the S20.
Thinking of getting this as does PD on the usb-c
