Checking USB Flash Drive
remybfg10k
I'm currently using Check Flash 1.03 to test the USB Flash disk (mini sd card) that came with my Nokia 5800XM as we have experienced alot of corrupted data, can anyone suggest any other programs to check the integrity of the mini sd card?
Download http://www.mikelab.kiev.ua/PROGRAMS/ChkFlsh.zip
remybfg10k
I assume this is not good:
Error at range [FFA00000h..100400000h]: device write error.
remybfg10k
h2testw results:
Test finished without errors.
You can now delete the test files *.h2w or verify them again.
Writing speed: 8.07 MByte/s
Reading speed: 18.7 MByte/s
H2testw v1.4
Sackboy
A friend had a corrupted micro-SD card with their new Nokia. It may be part of a batch. Take it to be swapped.
sparklehorse
I also have a lot of problems with my 5800 and the 8GB card that came with it.
It seems to me that it is a problem with incorrect handling of the FAT filesystem by the phone when writing to the memory card. Hope not though, because it would be easier to fix if it is the memory card. I'm with MTN - will try to swap it out when I get to a decent service center. But it looks like a common problem for the 5800s :crying:
sparklehorse
Did you manage to reliably reproduce the bug on the old firmware?
Using USB mode when connecting to a PC almost always resulted in fat errors...
