I've got a Tenda wireless router, I have a couple of PC's setup in my home network. Some connected over LAN and some over WIFI.
Every now and then the connection between the wireless and wired pc are lost. All pc's can then connect to the internet but only the wired pcs can see each other and same with wireless.The only way I have found to get it to work again is to reset my router and configure everything from the start. Now the only setting I change on the router is the ADSL connection and then the wireless network (SSID and Password). I've read something about bridging the 2 connections on the router but there is no setting for that on the router, i've checked.
Any suggestions as to what might be causing this and how I can fix it?
