Just remember to configure the panels output.I had a quick look at the specs of my system and it look like the 14ah setup is within the capability of my panel with the higher spec transformer.
We still have supplies of Ultratech 8AH/20AH and higher, Securiprod 50AH, LR Comtronics 20AH (not listed on our site loadshedbuddy.durban) but selling like hotcakes if you are still convinced that LifePo4 is the way to go.
We have also just got in fresh stocks (200) of the 7AH LR Comtronics LifePO4 at very favourable prices.
It is related to BrandonJLoadshedbuddy.durban ? ... is this related to @Thor
We have sold over 200 of the LR Comtronics Version , and hundreds of the Ultratech - people are replacing these in alarms and gate motors and not reporting problems.
Be careful about connecting in series and parrallel applications though. In these cases balancing of the cells is very important.
No it's not - maybe just the DN is similar
Mine's been in for about 8 months now, no issues yet ( paradox MG5050 and a vestech 7ah bat ).We were admittedly cautious, and still are . many people feel that it's working for them though.
Check your transformer.
At what point isn't it anecdotal any more?Only 6 of these LR Comtronics batteries left, will probably be sold by today. Securiprod also sold out. We have received over 3000 units of the ultratech battery though. Will be loading on our site.
As much as we promote the fact that these batteries are not a good fit for many applications, and the manufacturers are giving the same story, anecdotally we have technicians reporting having replaced 100's of alarm and gate motor batteries with these without problem.
I am still looking for something for the garage door motor. Mine needs a 24v battery. At this point, R400 for a lead acid sounds worth it.Electromann SA has 12V 10Ah LifePo4 batteries with 15A discharge current which could be used with
gate motors drawing high currents.
12,8V 10Ah 15A current draw.
7.2ah but they allow a high constant discharge burst with SLA.The D5 motor is supplied by the manufacturer with 7.2amp batteries. That is the standard, there is likely an issue with the motor if that's not enough.
Assuming the battery is completely dead?Calculate 700mA charge rate on 7ah, and six hours between load shedding bouts.
Fair post.Well, many on the forum here mock us because we caution against drop in lithium replacements. However many suppliers and technicians are reporting no adverse affects from using these batteries in their alarms and gate motors. how it all pans out in the long run, and whether these users actually realise 500 , 1000 or 2000 cycles - which is what the economics are based off, is another matter entirely that will become apparent after most of these batteries start reaching the 500 cycle arena.
My anecdotal evidence.Well, many on the forum here mock us because we caution against drop in lithium replacements. However many suppliers and technicians are reporting no adverse affects from using these batteries in their alarms and gate motors. how it all pans out in the long run, and whether these users actually realise 500 , 1000 or 2000 cycles - which is what the economics are based off, is another matter entirely that will become apparent after most of these batteries start reaching the 500 cycle arena.
Wow, so he stole the business name, masquerading as a sub-branch.Loadshedbuddy.durban ? ... is this related to @Thor
That's dumb, will need to deal with it via a lawyer now, pitty.
