FAX ring pattern
mocceb
Sabie, MP
On a Telkom landline, what is the default ring pattern for a FAX? Single rings, double rings, triple rings? And can it be changed? Just out of interest. Thanks for any knowledge shared.
If you are referring to a normal fax machine plugged in to a POTS , you can set the number of rings on the fax machine before the fax answers .
Two rings .
