Help in setting up a AP as wifi range extender /repeater.
bigboy529
Pretoria
Hi all
I found a long forgotten wireless AP in a box with some old junk, I actually never used it before, the PSU and antennas was still wrapped in plastic. It's a Intellinet 300N wireless access point.
Since I have a area in my house where the wifi coverage isn't too great, I thought I would set this up as a wireless range extender. Yes I know the best solution is to run a cable, but for now this would have to do until there's funds one day to do it properly.
I did a quick Google and tried setting it up, but I can't get it working so must be doing something wrong.
This thing has 4 modes, 1. Access Point, 2. Point-to-Point, 3. Point-to-Multi-Point, 4. Universal Repeater. BTW my main router is a TP-Link Archer D9.
1. I first gave the Intellinet a different IP address, outside the pool of the TP-Link.
2. I chose universal repeater mode on the Intellenet.
3. I set the SSID as well as all security settings and password exactly the same on both the Intellinet and TP-Link.
4. I however set the 2.4 GHz channel different on each, I think the TP-Link is set to 11 and the Intellinet to 4.
5. DHCP on the Intellinet is disabled.
What am I doing wrong, am I using the correct mode, is repeater correct or must it be in P2P mode?
From my quick Google, I understand if setting it up like this with the same SSID and security, devices will automatically jump from one router to another depending on which signal is the strongest.
Hi all
I've literally just started researching the same thing.
Apparently a lot of devices -- most Android phones unfortunately -- tries to stick to the weak but established link with all of it's life. So the same-SSID-same-security setting doesn't really help in many cases.
iOS devices seems to be better but I found my iPad Mini 1 seems to stick to the main Wifi AP too.
Anyway, what doesn't work? Does your phone not get an IP? Is there anywhere in the Intellinet to set the MAC address of the main AP? Anything about WDS?
My setup is an TP-Link Archer C9 as the main router and I have a TP-Link TL-MR3020 set up in Repeater mode connected wirelessly. I've considered running a cable between the two but not even sure if it will work.
Never mind: found out my iPad was connecting to the 5GHz channel which the MR3020 doesn't extend. Connecting to 2.4 Ghz works - I can see in the MR3020's Wifi stats page that the iPad connected to it. Speed isn't great though.
My iPhone jumps over to the Intellinet's wifi if I'm that side of the house, but then it's not getting internet anymore. So seams the TP-Link and Intellinet isn't talking properly, since the internet connection isn't passed from one to the other.
Which channel, the 2.4 GHz wifi's, as in the one set between 1 and 12?
You can choose any of those really, it all depeneds on how crowded your wifi space is (maybe many people are using channel 6 out of the box - so choose another)
Many Wifi AP's scan between frequencies to avoid "congestion" but set your Source and repeaster to the same channel and you should be golden
