Only telkom Provide 5 Usable Static ip With 1 Dynamic ip For R800 Other Are Costing more them 5000R pm For 50MBPSSorry to hijack thread - how much does a static IP typically cost?
R800 including the line?Only telkom Provide 5 Usable Static ip With 1 Dynamic ip For R800 Other Are Costing more them 5000R pm
Yes FTTB 50/25 MBPs - 800Pm With 5Static IpR800 including the line?
Do they supply you with a /29? Did you ask Afrihost if they could do the same?Yes FTTB 50/25 MBPs - 800Pm With 5Static Ip
Yes, they only provided me with the information below. Have you managed to set up and start using the /29 IPs?Do they supply you with a /29? Did you ask Afrihost if they could do the same?
Sorry, I'm confused did you ask Afrihost if they could do the same?Yes, they only provided me with the information below. Have you managed to set up and start using the /29 IPs?
Network Address: xx.xx.xx.152/29
Broadcast Address: xx.xx.xx.159
LAN Default Gateway: xx.xx.xx..153
LAN IP Addresses
xx.xx.xx.154
xx.xx.xx.155
xx.xx.xx.156
xx.xx.xx.157
xx.xx.xx.158
Hi the IP address should be issued to you dynamically but it will be a fixed IP, I see a public IP listed there?Hi everyone,
Has anyone got a telkom/openserve static ip address to work. i recently got an ip address and all they gave me was an ip address, ppoe usename and password and the attached document. They installed a Huawei EchoLife HG8145V5 GPON with only one port enabled which gives out a private ip address. im planning on using a miktotik router.
Ok so what is the problemHi, I meant to say Public Ip address. Thanks for the correction.
I get a private ip from the ONT/Router (192.168.100.xxx)Ok so what is the problem![]()
Yes so usually the public IP/Block is "routable" via your endpont, so this would be easier to test with a Mikrotik but you need to try and assign another IP to your router from the block they provided.I get a private ip from the ONT/Router (192.168.100.xxx)
