Help tracing a vodacom number???
LuckMaker
I recently received a nasty sms from an 071 number. A day later I received an apology ... maybe cos the perpetrator realised I have his/her number. I tried calling it back many times but it’s continuously off. I assume it’s a 3G sim card. Anyone out there knows how I can go about just finding out where this sms originated from? I’m sure it was a case of mistaken identity but for peace of mind and my families sake I need to know … Really appreciate any assistance
paul5186
Why worry?? Unless you have something to hide?
LuckMaker
You can't. At least not without a court order or breaking the law.
Yeah ... seems like its alot of work for Vodacom as well ... but working in an operations environment i am sure soem agent could look up the number atleast.
LuckMaker
Absolutely nothing to hide ... but if that message was meant for someone else … they could be in potential danger ... PLUS the inquisitive streak in me is getting the better off me ...
paul5186
You can only really google the number, maybe there is some reference to it?
chrissy
Aint no agents on here. Anyway, Vodacom can see who accessed the number on their system, so as nice as it is to spy, the papertrail will bite you in the butt.
LuckMaker
I know what you saying ... but if we dont question we will never learn ... & where there is a will there is a way ....
LuckMaker
With number porting you can't even be sure its a Voda number.
So the Mafia prefers Voda over MTN then.
I guess you right ... but I did a query with MTN using that number and they cam back saying number not on system ... where as with vodacom they came back saying OTP sent to my phone ... that’s why i assume its most likely a vodacom no.
simp
Try Crimeline if you're really concerned. (Not to tell you who the number belongs too, but to handle the situation)
Fader4
make a case of intimidation but honestly that is really being a spoilsport, its probly just some kid having fun and ur taking it all serious, relax
LuckMaker
That’s what I also really think and hopefully that is the case ... but it would be nice to know that, that is indeed the case ...
Maddmatt
Can't you go to the police station and see what they say? They might want to investigate it.
LuckMaker
I did do that ... but the station i went to told me they have had no success with past cases ... so no use. Unless it was a top priority case the police themslves will look into it ....
