HELP: wireles router supporting two 3g connections
Tsponge
Hi all.
I am seeking a wireless router that has two 3G modems. These can be external (USB) or internal or one of each (one built in + one plugged in via USB)
The reason I need this is because I have 4 people working on site at a development. The application they use is web based and there are no telkom lines there yet, but I do need speedish internet...
Also if this product isn't available yet could I hook up two Wireless 3G routers via the WAN port and have some sort of load sharing between them?
Please help!
I'd say get two 3G routers with LAN interfaces and connect them to a proper router to do the load balancing. Problem with connecting the second router to the WAN interface is that it'll see it as a failover connection, not sure if those routers support load balancing.
