marine1
Hey guys been using the same machine for a few years and I think it has finally died.
I need a new M/B and Ram.
The CPU and GPU are perfect.
Same with the PSU
Need some advice, I was using the following MB
https://www.asus.com/Motherboards/P8Z68V_PROGEN3/HelpDesk_CPU/
Using the i7 Intel CPU so want to keep that or am I screwed?
Will I have to also upgrade the CPU?
What MB do you recommend and what Ram?
And worst case, what CPU then ? Really want to avoid doing this because of cost.
I literally only play World of Warships and surf and download.
Looking at Esquire Shop as I have an account there. Also browsing Wootware
I am happy to look at AMD as well. (my GPU is NVIDIA - not even 6 months old)
Same with the PSU
