LTE Router Recommendation
REAPER
Hi
I am looking to buy an LTE router, and I would like your advice on which one I should go with.
I'm looking at the following:
Huawei B535
Alcatel HHV72 Linkhub 4G
ZTE MF286C
I will be using an MTN sim in the router.
Also is it possible to enable carrier aggregation on those routers?
Any advice will be appreciated.
huawei units like mtn lte .i use 2 of them zero downtime in 4 years
What download speeds do you get and can you enable carrier aggregation on the Huawei B535
aggregation ...no idea .speed on showmax tester a constant 60mb/s or something like that .ive seen over 120 but dont really look .
at the moment .tests are not reliable at all. especially upload its usually in the mid 20s download 38 now .
